Ported TB and throttle blade?
Old 03-28-2006, 03:58 PM
dnm12's Avatar
Default Ported TB and throttle blade?
I just got back my ported and polished throttle body from a sponser here and when i put it on my car the blade does not close all the way I took the TB off another car 00 i believe and mine is a 98 with ASR (or TCS whatever you want to call it) should i adjust the cables to get the throttle to just shut or what??? PLEASE HELP ME!!!!!!!
otherwise a ported and polished throttle body for an 00 camaro just went on the market
hopefully this helps here is the stock:
and here is the ported polished i have done nothing yet and am waiting to here before proceeding notice how the throttle is open just a little and the throttle stop doesn't hit the idle screw:
Old 03-28-2006, 04:20 PM
lgobraves's Avatar
I think a 98 and a 2000 are not interchangable. I think 1998 and 1999 will work and then 00, 01, 02 will work
Old 03-28-2006, 04:22 PM
RrCoX22's Avatar
a little confused.... you have your idle cable set right? ... because in the 2nd pic it's not even connected
Old 03-28-2006, 04:26 PM
dnm12's Avatar
i dont have a idle cable....fudgecicles i think this would work just fine by lenghtening the cable but i dont think i want to anyone else have any help?
Old 03-28-2006, 04:29 PM
dnm12's Avatar
any reason why everything bolts up fine? it seems like all i have to do is lengthen the throttle cable with the ASR brackets...
Old 03-28-2006, 04:47 PM
lgobraves's Avatar
that may be all you have to do...I'm sure someone else could fill you in on how they did it
Old 03-28-2006, 04:52 PM
Bo White's Avatar
The 98-99 and 00-04 TBs are not compatible, you will have to change the shafts out for it to work properly.
Old 03-28-2006, 04:53 PM
dnm12's Avatar
meaning??? i have my 98 right here!! what needs to be done??
i think i have an idea......but please help if you can
Old 03-28-2006, 06:17 PM
Bo White's Avatar
Got your PM and have returned with an answer . Just swap throttle shafts and youl be good. Who done the porting on the TB?
Old 03-28-2006, 06:45 PM
dnm12's Avatar
Thanks to Bo White for everything I owe ya!
Here it is working all great thanks to Bo
Old 03-28-2006, 06:50 PM
Bo White's Avatar
Much betta
