Doing a Ls6 intake swap
Im getting ready to take off my LS1 intake and put on a LS6 intake. But my ? is what matterials do i need for the swap i hear i need to replace some lines? also are there Intake maifold gaskets and do i need to replace to TB gassket? If someone could give me gm part numbers and where to get the best deal on these parts it would be much apreciated.
You will need 2 plugs for the back of the heads, and a crossover tube for the front. The new intake will have all the gaskets in it. Also when removing the intake take the big vac hose off the brake booster and follow it behind the intake it goes behind the oil pressure sending unit(which is plastic). When pulling the intake forward make sure that hose doesn't snap the sending unit off the block. Also texas speed carries those coolant plugs/tube.
