Best/Largest throttlebody for an LS6 intake?
I was thinking of upgrading and am unsure which to get or which works best?
I cant port mine out as I dont have the tools.
Porting your own TB is pretty easy and free, all you need is a Dremel or similar. Or you can get it done for like ~$75.
Porting won't make your TB bigger, it will remain at 78mm (I think, if not it's 75mm can't remember off the top off my head). But it will open up the opening of the TB, this will imporve air flow and is worth a reasonable amount of HP, even more so when you consider the cost.
TPIS offer a 90mm round and a 90mm oval TB for the LS6 intake, but the manifold also needs to be modified. Personally I don't think you can beat a STOCK ported TB, many people have made BIG bhp using them.
$75 bucks for a ported one here at new era performance one of our sponsers but id do it yourself for 35 bucks for a dremel at walmart and the expieriance
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=tbportcf|0
