ASP pulley worth it?
The engine will definitely rev faster because it's significantly lighter than the stock piece and you might pick up 8-10 rwhp. It's also much easier to remove and install compared to the stock balancer.
i got the asp with the overdrive alternator pulley because i have a decent sized system but aparently it isn't overdriven enough because my amps drop much more than they did before.
would just get a UD pulley and not an OD pulley because you are negateing the whole reason for getting an UD pulley, i have a decent sized system too and it is not that bad, just have a little dip in voltage around stop lights so i had the idle bumped up 150rpm
After reading about pulleys for a good year now - and waiting on a sponser to run a special - I finally said screw it and picked up a March Pulley from Thunder. They got a good package deal running right now.
I see it as a good 'complimentary' mod to the rest of my I/E bolt ons..
