90mm Pre Intake Tubeing
Old 04-06-2006, 09:51 PM
Jpr5690's Avatar
Default 90mm Pre Intake Tubeing
Anyone Have Any Ideas On What To Do As Far As The Duct Work Form The Air Box To The Tb ???
I Know Tsp Sells A 85mm Lid And I Have A 85 Mm Maf So Im Thinkin Im Gonna Have To Keep It To 85mm But I Dunno Is There A Better Way?
Old 04-06-2006, 10:22 PM
That's what she said...
TheBlurLS1's Avatar
http://www.intakehoses.com/Merchant2/merchant.mvc?
You could go to Home Depot and see if you can find something that will work.
And BTW - TSP's 85mm lids are on forever backorder from what i've been reading.
Old 04-07-2006, 01:38 AM
Jpr5690's Avatar
Old 04-07-2006, 06:43 AM
Detroitmuscle's Avatar
If you wanna use your stock MAF then I went to Home Dept and got a piece of 3.5" to 4" fernco, shaved down one side just a bit and it worked fine for $6.
Old 04-07-2006, 08:52 AM
Jpr5690's Avatar
im using 85mm maf and am also planning on some sort of 85mm lid
Old 04-07-2006, 09:47 AM
TheBlurLS1's Avatar
With enough grunt, you can actually make the stock bellow fit over the 90mm throttle body. This is what i plan on doing untill i get my new MAF/Lid.
Old 04-07-2006, 10:23 AM
Well if thats the case then a 4" piece of fernco should work fine.
Old 04-10-2006, 01:32 AM
Jpr5690's Avatar
My Slp Bellow Fit Pretty Easy On My 90mm Tb I Just Put Some Oil On It And It Slid Right On
Old 04-10-2006, 02:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Booyah! I did the same.
