Valve cover/coil bracket conversion
Old 04-07-2006, 02:52 PM
brians98ss's Avatar
Default Valve cover/coil bracket conversion
After getting new heads I have to convert from 98 valve covers to a 99+ valve cover set-up. I'm stumped right now as far as what size bolts I need to mount the coils to the coil mounting brackets and bolts needed to mount the brackets to the 99+ valve covers.
Did some searching on the site and came up with this:
LS1 coil bolt (m6x1x20, 9.8, pzor, 7114M, 14.2 flg od) = 11516423
LS1 coil stud (4 on RH, 5 on LH) (HFH, m6x1x40, special hd) = 12557539
Can anyone tell me if this is what I need?
Any info is greatly appreciated.
Old 04-08-2006, 04:27 PM
brians98ss's Avatar
For 98 owners, what bolts did you use?
Thanks.
Old 04-11-2006, 12:41 AM
WILWAXU's Avatar
to the top
