Power Steering Pump
Old 04-09-2006, 06:48 AM
Marblehead's Avatar
Default Power Steering Pump
What is the best way to drain and refill the power steering fluid? 2002 Z28
Old 04-11-2006, 07:51 AM
Marblehead's Avatar
Any suggestions would be greatly appreciated.
Old 04-11-2006, 08:39 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'd grab a turkey baster type of syringe and remove as much fluid as possible, then refill. That's the clean way.
The other way would be to drain the resevoir, then disconnect the return line and manually turn the pump to drain all the fluid. Now your need to refill it, and then go lock to lock to remove all of the air bubbles trapped in the system.
Old 04-11-2006, 01:01 PM
Marblehead's Avatar
Thank you very much!
