Steering shaft removal for pacesetters?
Old 04-09-2006, 08:05 PM
LS1FIRE's Avatar
Default Steering shaft removal for pacesetters?
Hello yall i may be doing a header install for my neighbor. Does the steering shaft need to be removed on the driver side to slide the headers up? Thanks
Old 04-09-2006, 08:14 PM
SouthernSilverSpeed's Avatar
I don't know if it is possible to squeeze them in w/o removing it, but if you do remove it, it will make your life sooooooooo much easier. Also it is simple to remove.
BROKEN's Avatar
nope they slide right in
Old 04-09-2006, 08:16 PM
BROKEN's Avatar
i help install them on a buddys car and they slide right in... but like southernsilverspeed said it might help on the install
Old 04-09-2006, 08:29 PM
2K2WS6TA's Avatar
Nope, just got done with a set, all I had to do was grind down the block tab
