What do i clean my MAF with?
Old 04-10-2006, 11:08 PM
KilerTA's Avatar
Default What do i clean my MAF with?
I just put in a K&n Fileter and i know since it new its covered in lots of K&N oil which ends up on the maf sensers which is making them dirty. So now here comes the ? what do i clean the sensior with? Ive heard a couple diffrent ideas. 1. Clean it with a que tip and rubbing alchool. 2. Take break cleaner to it. 3. Take computer parts cleaner to get it. 4. If anyone has any ideas please share.
Old 04-10-2006, 11:34 PM
eastcoastbumps's Avatar
Put it in a bag with non-clorinated brake cleaner and shake it gently. Do not touch or rub the MAF with anything.
Old 04-11-2006, 12:02 AM
calongo_SS's Avatar
I certianly would not do that. Buy some electrical contact cleaner and spray it off real well.
Old 04-11-2006, 01:07 AM
staringback05's Avatar
ive cleaned mine with intake cleaner, i didnt really spray down the actual maf and i didnt really even touch it, i cleaned around it and everything else an mines fine....just dont touch it or ull be setn off codes left and right
Old 04-11-2006, 02:52 AM
Shallow Bay's Avatar
Try this with some q-tips
Old 04-11-2006, 07:50 AM
NHRATA01's Avatar
I used rubbing alcohol and Qtips, done it a few times never had any issues. But of course it goes without saying be EXTREMELY gentle. Those resistors are very tiny, and the wiring very thin.
Old 04-11-2006, 02:10 PM
dailydriver's Avatar
I used the CRC Maf Cleaner. Just used the force of the straw aimed at the wires (I still have my screen in) a couple of times and let it air dry before reinstalling. This stuff is expensive (5.00/can), but it worked like a charm, just as claimed.
Old 04-11-2006, 02:17 PM
rgaynor85's Avatar
i used crc electrical parts cleaner with a q-tip gently worked great came out like new
Old 04-11-2006, 02:18 PM
SMSFRC99's Avatar
The scary thing is that this is right, If you call any of the aftermarket companys making MAF's they will tell you to use break clean. Believe my I was very hesitant
Old 04-11-2006, 02:33 PM
Grimes's Avatar
alcohol and q-tips + gentle hand works wonders. But the brake cleaner idea is good too if you have the shakes, lol.
Old 04-11-2006, 04:50 PM
hatdragracer's Avatar
I used a die grinder, drill, and a soft pink doily....didn't work though
Old 04-11-2006, 06:06 PM
sgtgeek's Avatar
CRC MAF Cleaner
http://www.midwayautosupply.com/deta...tion.asp?19908
Old 04-11-2006, 06:25 PM
FstBlkz28's Avatar
Electric Parts Cleaner ... comes in an aerosol can. Sprayed it off real well, let it dry.
