160* thermostat or 180* thermostat
which one would be a better choice i live in marylnad and am tryign to figure out which is better to go with out of the two or is the stock one fine
Keep in mind that the thremostat does not make the engine run cooler except in cold weather, it just takes it longer to come up to temp with a 160 degree t-stat. I run a 195, and it works good. It gets the engine up to 195 quickly, and the fans keep it there. Too cool an engine temp just yeilds accelerated engine wear from the condensibles not boiling away from the oil. This makes for sludge and a nasty engine. Get the oil temp up above 220 quickly and keep it there for long engine life.
A race engine can benefit from lower temps to avoid detonation, but this is not a good idea for a street engine.
Regards, John McGraw
