foam gasket for lid
foam gasket for lid
I just installed a used MTI clear lid on my LS1 and just read somewhere about a foam gasket. The lid did not come with any foam gasket and the left clamp has been popping off. I read about the placement of the front lip in the groove on the bottom lid and am gonna check it out tomorrow.
Does the foam gasket need to be on the bottom of the lid and if so where can I buy one?
Another ideas about why its not sealing up properly?
If you don't have one than you need to get one. You are not having a good seal and you could be getting dirt in you engine. If you call K&N they will usally send you one at no cost the did for my buddy. So its worth a try. If not you could try the weatherstripping just make sure the seal is good. K&N WITH NO SEAL=VERY BAD.
