Help on removing LS6 manifold
Old 04-13-2006, 08:48 AM
SSmokin99's Avatar
Default Help on removing LS6 manifold
My cousin just totalled his 01 SLP SS and he said I could take whatever I want. I want the LS6 manifold, but I don't know how to get it off. What steps would I need to do to take it off? The insurance company is picking up the car real soon, so I need to do this today asap. Help fast! Thanks
Old 04-13-2006, 09:11 AM
conan's Avatar
http://www.ls1howto.com/index.php?article=5
Old 04-13-2006, 09:29 AM
SSmokin99's Avatar
thanks man
Old 04-13-2006, 01:29 PM
GuitsBoy's Avatar
pull the intake and TB off and any hoses you can readily get to. get a 1/4" ratchet with an 8mm deep socket. Remove the 10 bolts and the 4 fuel rail bolts. Remove all the injector clips. remove rails with teh injectors plugged in. Pull forward. Disconnect everything from the back. Thats pretty much it.
Old 04-13-2006, 04:23 PM
noblesramair's Avatar
Its very simple just time consuming. You should pick up a haynes manual that will tell you how. That or follow the directions that were given to you but if you plan on taking other stuff off its easier just to get a manual for the car at your local auto parts store.
Old 04-13-2006, 04:35 PM
conan's Avatar
I forgot to mention when pulling the intake forward take the vac hose off the brake booster and follow it behind the intake, it goes behind the oil pressure sending unit. make sure when slideing the intake forward that hose doesnt brake the sending unit, it's plastic.
Old 04-13-2006, 05:14 PM
SSmokin99's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I just took it off right now and here's how it looks
Old 04-13-2006, 05:19 PM
conan's Avatar
Make sure you take the 2 plugs in the back of the heads and the front crossover tube for the coolant. the ls1 is differant
Old 04-13-2006, 05:24 PM
SSmokin99's Avatar
- 1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788 (Note, you can use a 2nd coolant pipe in place of these plugs if necessary)
Where can I get these?
Old 04-13-2006, 05:25 PM
SSmokin99's Avatar
Can you explain that a little better please?
Old 04-13-2006, 05:28 PM
SSmokin99's Avatar
those sponge lookin rectangles in the pic look a little bit dirty is that OK?
Old 04-13-2006, 05:39 PM
conan's Avatar
In this pic look at the gally cover with the 2 knock sensors see the silver tube it goes to the front and the rear of the heads. Look at the engine you just took the intake off of. You will see a plug on each side of the head (rear)and in the front you'll see a cross over tube from head to head. The ls1 intake has a bump in the bottom of the intake that allows that tube to run under the intake. The ls6 with the flat bottom doesn't have the room. You can reuse the ones out of the doner car.
http://www.ls1howto.com/howto/geniii...//IMAGE010.jpg
Old 04-14-2006, 11:06 PM
SSmokin99's Avatar
Old 04-14-2006, 11:45 PM
Jake the SSnake's Avatar
tsp sells them or type the #s in @sdpc or any other gm dealer tsp------------------------------>http://www.texas-speed.com/shop/cate...MID=1&catid=12
Old 04-14-2006, 11:57 PM
99camarosupersport's Avatar
get the TB too, and practice porting it perhaps...couldn't hurt. and yeah those dark pads are alright, just a little oily.
Old 04-15-2006, 12:40 AM
SSmokin99's Avatar
Do I just need to order 1 only?
Old 04-15-2006, 01:09 AM
Yes,all in one package
Old 04-17-2006, 11:16 PM
SSmokin99's Avatar
By the pictures I have posted above, can you tell its an LS6 manifold??
Old 04-17-2006, 11:29 PM
That's what she said...
TheBlurLS1's Avatar
Yes that's definatly an LS6, the bottom is flat. LS1 intakes have a round bottom. Send a PM to LS1_SS and he'll probably buy the LS1 intake from you, you can thank me later.
If they haven't gotten the car yet, just go get the plugs and crossover pipe off of it.
BTW - the wire connecting the two knock sensors together has a plastic clip that you need to un-tape it from the wire and remove as well. Even it is too big to fit under the manifold.
And be EXTRA CAREFUL that you do not break off the oil pressure sending unit! It screws into the block behind the manifold on the driverside. The brake booster hose loves to break it off while pulling an intake manifold out.
Old 04-18-2006, 09:01 AM
silverlt1ss's Avatar
with an air rachet you can have it off in 20 min
