spark plug wire clearance
That's what she said...
Before I put my cam in, I had MSD boots resting on the header tubes for like 8 months with no problems. I later found little white burnt spots on like 4 of them about a week after I put the cam in.
I broke out the multi-meter and checked them all out. One was reading a little more resistance than the rest, but still less than the stockers.
I rotated the end of the plug wire that snaps onto the coil pack so it points away from where the header tube contact was, this helps keep it off a bit. You can also take your metal boot protectors off the stockers and stick them on the new plugs wires if you want.
Originally Posted by HSV-GTS-300
LS2 plug wires will fit and the 90 deg moulded end gives good clearance.
Sorry I don't know the part number.
I may have to get a set!
Originally Posted by TheBlurLS1
Awesome! Are those MSD LS2 wires? OEM? Are you sure they snap into the coil packs from an LS1 correctly?
Yes they fit and there is no problem.
LS2/LS7 spark plug wires = 89018058
There ya go fella's. I think I am going to pick some up as well. I'm liking that idea.
Originally Posted by Zymosis
What did they cost? Like 85 bucks for a set?
eBay FTW!
http://cgi.ebay.com/ebaymotors/ws/eB...3AAAQ%3AUS%3A1
Search that guys other auctions or send him an email, he may have/be able to get you another set. I know he was also selling some blue ones.
Originally Posted by Mustang5.Ohater
How much easier is it to get the boot on the #8 plug?
