Catted Y-Pipe Fit Question?
I'm goin to be getting pacesetter lt's with the tsp catted y-pipe. I currently have on an slp lm and the slp ory (dumping for the header and ypipe setup). Will the ypipe and headers slide right up to the end of the catback or will there be some fitment problems and require grinding, cutting, etc??
I have the loudmouth and the TSP catted Y too. had to do a bit of coaxing to get it together. We also had to cut about 1" off the back of the Y pipe to get it to go into the LM. Had to hit the inside of the LM with a small die grinder a bit. Then grease it up with wheel bearing grease then hammer her in to the Y pipe. It will go. First time putting it on takes some patience and a BFH. You will love how its sounds though. Sounds mean!!!!!
