will this fix y pipe banging?
Old 04-18-2006, 01:26 PM
SPL
SPL's Avatar
Default will this fix y pipe banging?
I can't stand how my y pipe bangs after my lt + ory install. I know poly motor mounts will probably fix the problem, but I don't want to mess with that right now. Will putting some heater hose between the floorboard and the y pipe at the tight spots stop the banging? What could I use to secure the hose to the y pipe? I thought about just duck taping some on there but I'm worried the tape might catch fire and zip ties would probably melt.
Old 04-18-2006, 03:48 PM
SSU's Drunk Typing Whore
Lithium's Avatar
yeah hose is fine, a few people have suggested that to me actually.
have you tried adjusting it at all?
Old 04-18-2006, 03:50 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Give it a shot...I've done poly motor mounts, and that **** took me two weekends (I got so pissed off the first weekend I just did one and said screw it).
Old 04-18-2006, 04:06 PM
SPL
SPL's Avatar
Yeah, I'm going to try it tonight. I still don't know what to use to secure the hose though. Think duck tape will catch fire?
Old 04-18-2006, 04:09 PM
jmm98LS1's Avatar
I don't think it will catch fire, but it'll sure as hell melt.
Old 04-18-2006, 04:14 PM
MeentSS02's Avatar
Just go to your local Home Depot or Lowe's and get a big hose clamp.
Old 04-18-2006, 04:25 PM
SPL
SPL's Avatar
I tried autozone and oreilly's but they didn't have any hose clamps big enough. I'll check out home depot. Thanks.
Old 04-18-2006, 04:26 PM
MeentSS02's Avatar
Home Depot will.
Old 04-18-2006, 06:58 PM
Danny2tek's Avatar
Thats what Im running right now. I just used a big hose clamp fed it thru the hose and clamped it around the pipe. Issue resolved.
Old 04-18-2006, 07:38 PM
TruBloodTransAm's Avatar
I was having the same problem not to long ago. I went to Lowes Hardware and bought some hi-temp heater hose, took my pocket knife and cut it open lengthwise and then get a hose clamp and secured the open rubber hose in between my driver side floorboard and the ORY. No more banging.
I've also heard of people who have used a breaker bar to widen the gap between the floorboard and ORY (when the car is up on the lift).
Old 04-18-2006, 07:48 PM
bigti99a's Avatar
i wrapped my y pipe with that thermal header wrap. seems to have quited it down a bit.
Old 04-18-2006, 09:34 PM
00silver6's Avatar
spl try a bump stop its on the stock y but put n the after market y it dont come with one but that should stop your y pipe from bothering ya.if you have your old y pipe you took off youll see it on the pipe itself its the piece that bolted to the trans you can fab your own or buy one i seen one on the slp website
