QTP, Electric Cutout and Subframes Install Problem
Old 04-18-2006, 09:35 PM
tonycook's Avatar
Default QTP, Electric Cutout and Subframes Install Problem
I have Kenny Brown Double Diamond subframe connectors welded in place. Just installed QTP headers and cannot fit the off road pipe and cutouts because of the subframe connectors.
What are my choices?
The only answer I can see is to remove the subframe connectors, which will be quite time consuming and replace with subframe connectors that will fit. If I go this route, which subframe connectors will give the most clearance for the exhaust?
Thanks,
Tony Cook
Old 04-18-2006, 09:59 PM
ShevrolayZ28's Avatar
That sucks. Would a regular ypipe fit?
Old 04-19-2006, 06:13 AM
tonycook's Avatar
Not sure. I would like to keep the cutout.
Old 04-19-2006, 07:08 AM
slow trap's Avatar
the tubular or boxed subframe connectors like the bmr or equivalent might be your only solution.they just run along your frame rail.
Old 04-19-2006, 07:18 AM
tonycook's Avatar
That's what I'll probably end up doing. I don't look forward to cutting the old sfc off.
Old 04-19-2006, 11:29 AM
65chevellels1's Avatar
Got any room to fit one of these? www.not-a-sponsor.net top of the line full stainless cutout
