clips on coilpacks
If I'm thinking of the same white plastic clips, all they do is secure the electical harness to the coil packs (Keep you from disconnecting the harness). If I rememeber correctly even with them removed you still need a small screwdriver to disconnect the connector. I think you will OK with removing them. The connector is a standard GM style connector with a lab that hold them connected. The plastic slip is just additional method of keeping them from being disconnected.
