need input on a cut-out
Old 04-24-2006, 01:20 PM
staringback05's Avatar
Default need input on a cut-out
im thinking about getting a cutout, so id like to hear what everybody has or what they know about them. how reiable are the electric ones? how hard are the ones to close that are manual? how much do shops usually charge to do it? what kind of gain would i get? what are the negatives? what is the best brand?.....and anything else anybody would add....thanks
Old 04-24-2006, 01:27 PM
formula001's Avatar
I am going on just about a year with my electric cutout and its still going strong. No problems yet. Don't close it to often so maybe thats why. It depends on where you mount the cutout to determine the difficulty of capping it. I had my cutout welded in for 25 dollars at a local shop, some charge more some charge less. Cant think of any negitives so far and I am using a QTP. Hope this helps.
Old 04-24-2006, 01:32 PM
SSU's Drunk Typing Whore
Lithium's Avatar
how reiable are the electric ones? - Pretty reliable. There are several threads floating around here that have polls on the most reliable ones. I believe that QTP was the winner.
how hard are the ones to close that are manual? - Not hard at all. Its just three wingnuts and a plate.
what kind of gain would i get? - 10 or so.
what are the negatives? - Nothing. Just more noise and more hp.
what is the best brand? - I say QTP.
how much do shops usually charge to do it? - Should not be more then 50 bucks.
Its one if not the best mod you can do.
Old 04-24-2006, 01:35 PM
thanks guys, one more thing does it require any tuning? i mean does the ecm since it and make it run richer or anything?
Old 04-24-2006, 01:39 PM
formula001's Avatar
Nope you will be alright with the tune your on.
Old 04-24-2006, 01:41 PM
Lithium's Avatar
Old 04-24-2006, 01:48 PM
TAwananbe's Avatar
Q tech has failed 4 times on me..........in 2 years......most times withing a few weeks of installing again...
Stored winters, no rain........still SUXKS!!!!!!!!!
Old 04-24-2006, 01:51 PM
formula001's Avatar
Alot of peoples motors fail because they hold the switch to long you can almost hear when its all the way open or closed, but they will fail if you keep the switch down to long and keep grinding it.
Old 04-24-2006, 01:53 PM
Lithium's Avatar
https://ls1tech.com/forums/showthrea...ghlight=cutout
Old 04-24-2006, 03:01 PM
chrs1313's Avatar
go with the one i got also one year now and she is still going strong and seals up nicely
ps i do drive in the snow too
Old 04-24-2006, 08:45 PM
Kanes2413's Avatar
byunspeed has a good price on them too im thinking of buying the electric one
Old 04-24-2006, 08:47 PM
Firehawk526's Avatar
DMH's work great, but pricey and don't offer much ground clearance compared to the QTP:
Have mine welded into the Y-pipe behind the cats(pg 1 of cardomain)
http://www.dmhperformance.com/ecutoutiframe.htm
