Turning your own pulley
Old 04-25-2006, 05:28 AM
robin427's Avatar
Default Turning your own pulley
Thinking of making my own underdrive pulley on my new Myford lathe - has anyone done anything similar? Doesn't look like too complicated a project and these things are very accurate...
Old 04-25-2006, 07:54 AM
GuitsBoy's Avatar
Since the pulley is also the dampener, you need some sort of viscous material between the inner hub and outer ring. And you need that viscous material not to come apart at 6 to 7K rpm.
Old 04-25-2006, 08:02 AM
robin427's Avatar
Interesting... is this visible on the stock pulley? What kind of materials would be suitable?
Old 04-25-2006, 08:13 AM
GuitsBoy's Avatar
Yes its visable on the stocker. Looks to be some sort of wrapped neoprene or silicone rubber.
Old 04-25-2006, 08:18 AM
robin427's Avatar
Bit more of a challenge to rise to... could be a good little earner if I get it right!!!
Old 04-25-2006, 03:59 PM
98LS-WON's Avatar
Good luck, Harmonics and Vibration/Resonance is a painful process. Hope you don't break your crank perfecting it.
Old 04-25-2006, 04:30 PM
robin427's Avatar
Hmmm... I'll be honest, didn't actually realise they were in two parts... probably won't bother in that case - I've got a lot to learn!!!
