Fast 90/90 or ???
Old 04-25-2006, 05:02 PM
Jefro6996's Avatar
Default Fast 90/90 or ???
I have a H/C car now with 420 rwhp and want to get to around 450-460 before i put on the nitrous. Would ti be worth it to spend the money on a fast 90/nw90 or keep my ls6/bbk80mm. Im running out of things to do and want to get the most n/a that i can. I had 420 with a 4'' catback now i have true duals. Mods are tsp 231/237, patriot 5.3's, underdrive pulley, lid, ls6, bbk 80mm, long tubes, forged pistons, 85mm maf. What else can i do?
Old 04-25-2006, 05:03 PM
taintedmeat's Avatar
fast90 > ls6
Old 04-25-2006, 05:07 PM
02TransAm/Batmobile's Avatar
if you want to reach 450 then yea, . . or i would look into the tpis ls6 90, . . they take your ls6 intake and cut off a piece of it and attach a larger opening, its cheaper than buyin a fast intake and others including myself say that the horsepower gain from a fast intake is attributed to its larger opening, . .
Old 04-25-2006, 05:55 PM
Jefro6996's Avatar
I think ill give tpis a call and talk to them about what i could gain from swapping to that and having them port the intake to match the heads also.
Old 04-25-2006, 08:22 PM
SUX2BU's Avatar
Is it really cheaper? You figure the Fast 90 mm intake is about $750 minus the $350 you can get for selling your LS6 is about $400. How much does TPiS charge for the operation plus shipping both ways?
Old 04-25-2006, 08:32 PM
SSU's Drunk Typing Whore
Lithium's Avatar
true you can offset the cost of the fast 90 by selling off what you have now...its definitely worth it IMO.
Old 04-25-2006, 08:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Or you can never buy an LS6 and skip straight to a used FAST. That was what I did.
Old 04-25-2006, 08:40 PM
Lithium's Avatar
yeah then fork out the extra 300 bucks that you would get from the ls6
Pay to play!
Old 04-25-2006, 09:50 PM
n2o
n2o's Avatar
A Fast 90/90 setup will not get you there. You will probaly need some better heads and then you might not even need a different intake. Or you could tune it and jet up.
Old 04-25-2006, 10:16 PM
That's what she said...
TheBlurLS1's Avatar
^^^ I'm with him. ^^^
Plus, when you put the spray on the car, it would be nice to have a safe nitrous tune in it. You will loose quite a bit of power NA when you yank a little timing.
Old 04-25-2006, 10:42 PM
SUX2BU's Avatar
Hell guys are close to there with stock heads. i say keep the heaps and throw a bvigger cam in it. TREX say what?
Old 04-26-2006, 10:39 AM
kpforce1's Avatar
You could throw an electric water pump on there with a fast 90/90 setup and a good tune... That could put you where you want to be. What headers are you using? Long tube headers with merge collectors and the FAST 90/90 and good tune would probably get you there too.
Old 04-26-2006, 01:00 PM
92SilverSHO's Avatar
a ported fast setup Might get you 25rwhp.
Old 04-26-2006, 01:55 PM
n2o
n2o's Avatar
He probaly does not have the ptv clearance to run a bigger cam. Many of the PP 5.3's have been milled considerably. I am speaking from experience here, my 224/224 .560/.560 was hitting on 4 pistons with pp 5.3's. Now I was spinning the motor to 6600 rpm, but still.
Old 04-26-2006, 02:50 PM
WS-Sick's Avatar
Good luck. I see those are mustang dyno numbers so they read lower than dynojets anyways. You'll probably need a GOOD set of heads or rework the ones you have. A bigger cam isn't always the answer of course but heads are vital. You will just have to match your setup properly. If you mangae to get the numbers you want you'll be way up there in the H/C dyno list. Do you take your car to the track at all? Those are already good numbers that you have there. What heads and cam are you running now?
Old 04-26-2006, 05:58 PM
SUX2BU's Avatar
The guy has forged pistons so i'm assuming they have valve reliefs in them.
Old 04-28-2006, 10:00 PM
Jefro6996's Avatar
The pistons do have -2cc valve reliefs and i was thinking of having a custom ground cam put it. i have a tsp 231/237 now. i really dont want to have to pull the heads or spend an extra 2000 for a better set of heads. The biggest reason i want more n/a power is because i know i will lose some when i have to drop the timing for the n20. i will probably do the fast 90/90 since i can sell the ls6 intake. When i had the shop install the 231/237 they checked the p/v clearance and said there was plenty of room. I dont know if i want to swap the cam cuz i have a really nice flat torque curve.
Old 04-28-2006, 10:18 PM
SUX2BU's Avatar
I think you need a better cam. hell there are close to full weight cam only cars running your times.
Old 04-28-2006, 10:23 PM
RoastEmSS's Avatar
talk to stangkilr, i know he made 449 rwhp with the same setup as u except a FAST 90/90, so yes it is def worth it
Old 04-30-2006, 02:02 PM
Jefro6996's Avatar
I have wanted to get a new cam for a while. But how does my p/v clearnce compare to stock now since i have the p.p. 5.3l heads. Are they milled and did i lose some clearance and did i get any closer to stock with my -2cc valve reliefs? And who do you recommend for a custom ground cam that can get over 450rwhp with the fast 90/90. Also how big of a cam can i go?
