Header leak
Old 04-27-2006, 08:10 PM
tylerdj's Avatar
Default Header leak
When we first installed my headers we used the paper gaskets that pacesetter gives you. Well I decided to go ahead and swap them out with some OEM gaskets. After I installed the new OEM gasket I have a bad leak because the gasket won't seal completely....I believe this is due to the flange being slightly warped and yes all the bolts are torqued down right. It sealed fine with the paper gaskets though, so should I just put another paper gasket in or is there something else I could do? Thanks ahead for the help
Old 04-27-2006, 08:24 PM
nyg215's Avatar
did u get all he paper gasket off? if not that could be causing the leak.
Old 04-27-2006, 08:34 PM
tylerdj's Avatar
Yes...i made completely sure that I scraped every bit of it off.
Old 04-27-2006, 09:09 PM
Order 66's Avatar
You might need to pull the header and place it on a flat surface to see if its straight. Might be warped.
Old 04-27-2006, 10:11 PM
Gary98Z's Avatar
Try using Percy's header gaskets. They are pretty darn thick. I used them after my oem replacement gasket was leaking on the passenger side.
So far so good.
Gary
Old 04-27-2006, 10:17 PM
tylerdj's Avatar
Gary - do you know who sells them? (auto zone, etc.)
Thanks for the help guys
Old 04-27-2006, 11:30 PM
2K2WS6TA's Avatar
Get them from summit racing p/n PHP-66032, one bad thing it ships on 6/01 (must be a popular item) I'd check some of the other sponsors to see if they have them in stock
Old 04-27-2006, 11:33 PM
tylerdj's Avatar
what about some of the gaskets from autozone or similar stores...at least for a temporary fix until I can get some good gaskets...because this leak drives me crazy when I'm driving
Old 04-27-2006, 11:36 PM
SUX2BU's Avatar
I just threw mine away that came with my Kooks.
Old 04-27-2006, 11:54 PM
2K2WS6TA's Avatar
Might try new stock metal gaskets, the old ones might be too compressed (due to the age) that they don't seal, they're only about $20 so it's not too bad to give it a shot, you can get them from the dealer, or from SDPC.
Or you could just get another set of paper gaskets to hold you over until the percys are available
Old 04-28-2006, 05:52 AM
tylerdj's Avatar
I have some brand new oem gaskets on there now....and they won't seal. Do they have paper gaskets at any car parts stores?
Old 04-28-2006, 04:12 PM
Gary98Z's Avatar
I ordered mine from Speed Inc. I emailed them about header leaks and they said most of the time, they don't have problems with the OEM gaskets. But the few times they do, they use Percys. They have awesome service and quick turn around times.
Good luck !
Gary
Old 04-28-2006, 05:32 PM
jimmy 2 Times's Avatar
how do you know you have a header leak?
Old 04-29-2006, 09:28 PM
bad6as's Avatar
does it sould like a tick tick tick tick? or like a whoosh sound
Old 04-29-2006, 11:41 PM
Shallow Bay's Avatar
the tick tick tick sound
Old 05-05-2006, 11:48 PM
tylerdj's Avatar
anyone have a paper gasket they would sell me to hold me over for now?
Old 05-06-2006, 12:42 AM
ShevrolayZ28's Avatar
Felpro's are pretty thick, and readily available at the local parts stores.
Old 05-06-2006, 01:13 AM
What's a Sticky?
97MysticZ's Avatar
Yes, you should be able to get Percy's gaskets at any local part stores- at least Autozone for sure and they probably have the LS1 set in stock. They are a little pricey, about $35, but it will be the last ones you ever have to buy.
Old 05-06-2006, 05:39 AM
tylerdj's Avatar
thanks
Old 05-08-2006, 10:44 AM
None of the Autozones I called had Percy's. $35?...that would be Percy's reusable aluminum header gaskets. They also make a carbon header gasket for around $14, and from the sound of the manufacturer's discription the carbon gasket might be the better of the two for sealing a leaky situation.
Has anyone on here used Percy's carbon header gaskets?
