QTPs, ORY, Borlamouth and TTP's V3 cam
Well here is how the car sounds so far. Tuning still needs to be completed but for you guys that want to know how it sounds, well here you go.
5700 RPM pull
5700 RPM pull
Yes those numbers were before the headers and cam. New numbers are unknown since they couldn't tune yet because of my V rated rear tires. The full dyno tune will be done on Tuesday when they switch my fronts with the rears since the fronts are Z rated. That's why they only pulled to 5700 instead of the full 6600.
Originally Posted by Deutch420
link doesnt seem to work for me. i tried MF and IE... hmmmm
Here's the vid on ls1tech
5700 rpm pull (ls1tech host)
Originally Posted by Roarin_8
Here's the 6600 rpm pull. Car made 365rwhp, lost 25 due to my lifters. That's the next thing to get changed.
6600 rpm pull
6600 rpm pull
Isn't that the same problem that ULTIMATEORANGESS had (dynoing low numbers with the TTP V3 because of bad/faulty lifters) ?
From the thread it sounded like the pushrods theyre using is too short. The higher lift cams have to come with a smaller base circle or else it wont fit in the motor. It doesnt make sense.
