Everything needed for a Fast 90/90NW install
Old 04-29-2006, 04:54 PM
ws6formula98's Avatar
Default Everything needed for a Fast 90/90NW install
What else do you need beside the intake and T/B? Any seals or any other things? Thanks
Old 04-29-2006, 07:06 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
If you get it brand new then it should come with new gaskets, bolts, ect.
Old 04-29-2006, 07:09 PM
SSU's Drunk Typing Whore
Lithium's Avatar
I did not receive the port gaskets for the manifold... I had to talk to tsp and buy some.
Old 04-29-2006, 07:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You can reuse the old ones, but I know for a fact that they seem to not be thick enough to make a decent seal.
Old 04-29-2006, 07:31 PM
Lithium's Avatar
Yeah I was not bright enough to keep the ones off the ls6 that I sold. But it is recommended to reuse the old ones if they are in good condition...
Old 04-29-2006, 07:41 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Lithium
Yeah I was not bright enough to keep the ones off the ls6 that I sold. ...
Old 04-29-2006, 07:42 PM
ZL1Killa's Avatar
MAKE SURE NOT TO USE THE FAST BOLTS AS THEY WILL RUST!! they are simply black steel.
I used my original intake bolts and they worked fine, they are actually longer than the fast bolts. Make sure you have all the seals and that is pretty much it.
I got all of my small intake bolts from lower motor speedway car show..the food lion autofair, but I'm sure you can find small stainless steel bolts somewhere that will work, like NAPA or a hardware store.
Old 04-29-2006, 07:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Rust = horsepower
Everyone knows that!
Old 04-29-2006, 11:43 PM
Well, I will place the order for intake and TB and cant wait to put it on. By the way, can you feel the differents? its a 98 ls1
Old 04-30-2006, 12:12 AM
Quik's Avatar
Originally Posted by orangeapeel
Rust = horsepower
reason why mustangs are fast
Old 04-30-2006, 12:28 AM
That's what she said...
TheBlurLS1's Avatar
You will also need a new front coolant crossover pipe for the front and 2 coolant plugs for the back, just like if you were doing an LS6 swap. Check LS1howto.com for more info and part numbers on those pieces.
Byunspeed has great deals on the FAST manifold, and also sells the new port gaskets. There's usually a group purchase going on all the time on them, so check the sponsers for sale section before you buy.
Old 04-30-2006, 04:20 AM
TAQuickness's Avatar
I've had bad luck with the Comp intake port gaskets. I would stick with an OEM gasket.
Old 04-30-2006, 05:29 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The newer ones work way better than the used ones.
Old 04-30-2006, 12:11 PM
Then I suppose the new one's I installed should have worked with out issue.
Old 04-30-2006, 02:27 PM
35th SS's Avatar
got mine from him.it came with everything.hell ya you can feel the difference.get it.
