I have a ls6 intake I bpught off a guy on here and in shipping, on the back of the intake the big cooling line I belive broke off but will that whole circle piece come out so I can replace it or is the whole intake junk??
that's your map sensor and the big line that connects to it is a vacuum hose for the brake booster. i've read they pop out and can be replaced if neccessary
Post some pictures of the damage. The thing you're turning is the MAP sensor. You may actually be able to fix it with a little JB weld if it's not that bad.
