Bellow size..
Bellow size..
Im looking at a webstie that sells silcone hose's Im about to order one, but wanted to make sure I get the right size, I dont have my TB with me at work so could someone tell me if this is worng.
TB inlet side 4in
MAF inlet side 3.5in.
Or are they both 3.5in on both sides.
BTW this is a NW TB.
Thanks!
TB inlet side 4in
Thanks!
Do you have a 85mm MAF? If so just get the SLP smooth bellow thats what I did and it fit w/ no problems, I do have the 85mm TSP lid though. Also the fernco bellows arent as flexible or angled like the SLP and could cause you to crack the MAF or lid because of the angle it must bend at on a F-body.
SSU's Drunk Typing Whore
4" was way to big for my nw tb and slp maf.
3"x3" fit after a pretty intense wrestleing match.
Last edited by Lithium; 05-01-2006 at 06:31 PM. Reason: Did not get home till 5 in the morning...so brain is not working.
Originally Posted by orangeapeel
I held your hand through that match!
Cool looks like Ill be getting 3.5/3in. I dotn run a MAF so thats not an issue. I would order the SLP one but Ive found a website that sells them about less then half than what SLP wants for them. Plus Ive already had one of those . Id keep the stock one on there, but I ditched the power ring, ordered a new lid & Im not cutting this one so Im going to put the nozzles in the bellow instead of the power ring.
