Pacsetter ORY or TSP ORY
Old 05-01-2006, 06:04 PM
josepy121380's Avatar
Default Pacsetter ORY or TSP ORY
Pacsetter ORY or TSP ORY I have both of these. Which one would be better with my pacsetter lt's that I just bought. Any help would be appreciated.
Old 05-01-2006, 09:52 PM
Raise's Avatar
well, the pacesetter will give u better ground clearance. the tsp ory hangs low as hell. they will both flow the same, despite the flattened out drivers side section of the pacesetter ory. i guess it will come down to which one fits better
Old 05-01-2006, 09:55 PM
JDP
JDP's Avatar
JET HOT! its jet hot coated, has great ground clearance, and it doesnt bang or anything annoying like that
Old 05-01-2006, 09:56 PM
Luna's Avatar
Not too fond of the pacesetter personally, I'd go with the TSP
Old 05-01-2006, 10:24 PM
That's what she said...
TheBlurLS1's Avatar
You can make the TSP y-pipe fit nice if you put enough time into it. I would HIGHLY recommend getting a set of poly motor mounts and installing them while the exhaust is out. You will be able to get the clearances alot tighter, without it hitting the floorboard.
Putting the poly-mounts in with the headers in place later is a royal PITA like you would not believe. They are only like $50 too, you'll thank me.
Old 05-01-2006, 10:35 PM
thanks for the input. it has helped a lot
Old 05-01-2006, 11:42 PM
Luna's Avatar
+1 for the motor mounts, I've had nightmares about my experience putting in motor mounts with the headers on!
Ok not really, but I should ,it is just that bad!
Old 05-02-2006, 05:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
+2 for the motor mounts, and or transmission mounts. Both are a nice edition and will help out with most y-pipe setups. Whichever route that you go, I would suggest these too.
Old 05-02-2006, 05:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That might be what your rattling noise is....
