EGR - AIR - O2 Sensors - Motor/Tranny mount FAQ! - Page 4 - LS1TECH
Thread Tools Search this Thread
Old 02-15-2009, 10:06 AM   #61
Camaro ss 2001's Avatar
Thanx 4 the INFO ^_^
Camaro ss 2001 is offline   Reply With Quote
Old 02-19-2009, 05:19 PM   #62
garygnu's Avatar
can the air pump be used as vacum pump on the pcv system ? and how much vacum is safe using an electrical vacum pump ?
garygnu is offline   Reply With Quote
Old 02-20-2009, 09:29 PM   #63
Nick_Rapitis's Avatar
if i need to pass obdII and visual, what would i need to do if im installing pacesetter with air/egr and a catted y pipe? will tuning out the ses codes cause me to fail? will they show up as not ready? any info would be great! thanks!
Nick_Rapitis is offline   Reply With Quote
Old 04-10-2009, 09:22 PM   #64
Hey I have a question about my cat if my exhuast pipes are too large is there any reason to put a cat on backwards for more back pressure??? my cat is in the rear right before my muffler...
stlakid is offline   Reply With Quote
Old 05-07-2009, 06:50 PM   #65
Anyone familiar with Northern Virginia emissions? I have some Kooks long tubes ready to go on my 2002 Z28 but I need to pass emissions. If I have the air and o2 codes deleted will the car pass? Sorry if this has been covered. I did search around a bit and can't find the answer. Thanks
mrlader is offline   Reply With Quote
Old 05-12-2009, 11:02 PM   #66
The Fugitive's Avatar
Quote:
Originally Posted by nrs2420 View Post
I know it old but does tuning out the codes give not ready monitors?
Quote:
Originally Posted by Empatho View Post
Quote:
Originally Posted by TFord View Post
Hey I gotta question??? I live in OR and you just have to pass the scan. I plan on getting LT's, but can I remove my EGR/AIR system, and delete the codes + rear O2 sensors, and still pass emissions?
Quote:
I am with these guys can anyone answer this because I need to know what is the deal with the scanner. Also if I delete a SES code right before the smog scan test will that give me a not ready code?
The Fugitive is offline   Reply With Quote
Old 05-25-2009, 10:06 AM   #67
Hey everyone ! I am about to get a set of ceramic coated pacesetter headers with smog fittings for the 00-02 fbodies and a TSP catted y pipe with 3" magnaflow high flow cats, corvette heated 02s for the front and 02 sims for the rear. Do I need anything else in order to pass the Houston inspection??? Thanks
aggiebutter is offline   Reply With Quote
Old 05-25-2009, 01:29 PM   #68
Quote:
not sure what the inspectors do in houston but you should be fine as far as obdII goes and visual...if they do a sniffer you might not pass...if they are super picky on visual inspection you might not pass since you relocated the cats...good luck though man
Old 05-25-2009, 05:05 PM   #69
Thanks Nick. Right now I'm running just an Offroad Y with the codes deleted. I figure If I'm gonna have to change some things to pass, then I might as well add headers and whatever else I can.
Old 05-25-2009, 05:49 PM   #70
i just put in the same headers and they are very nice!...if you deleted the codes you wont need o2 sims...if they dont do a visual inspection then you dont have to do the cats...if you do need cats for visual then you can gut them if you want since you already took care of the rear o2 codes...its up to you...some guys swear by keeping cats on some hate em, both ways have their pros and cons...
Old 05-30-2009, 03:41 PM   #71
Her LS1's Avatar
Default AIR code P0410
Has anyone else seen this code and if so, what does it mean? Is the pump failing or just a bad sensor. I have a '00 T/A BTW, lightly modded. Just a loudmouth, lid and K&N.
Her LS1 is offline   Reply With Quote
Old 05-30-2009, 06:36 PM   #72
probably just need a new air valve...5 buck and 5 minutes of your time...
Old 05-31-2009, 08:32 AM   #73
Her LS1's Avatar
Thank you Nick. I'll let my husband know. From the sig, you can see HerLS1 drives a Camaro. My husband doesn't have an LS1TECH login (what's up with that, who owns an F-body and doesn't have a login to LS1Tech?) so he hacked in using mine
Old 05-31-2009, 07:15 PM   #74
no problem...when you change the air valve be ready with i think two 1" wrenches (its been a while since i changed mine) just unbolt the two bolts and pull the thing out of the rubber hose, then use the wrenches to separate the valve from the pipe...if its anything like mine you are gonna need a ton of muscle to get the pipe off the valve...
Old 07-06-2009, 10:14 PM   #75
I just have some information regarding smog part interchangeability in case anyone ever runs into the same issues I have when smogging their f-body. I have a 1998 z28 and I installed 2000 exhaust manifolds and cats. The AIR injection needs to be a 2000 as well as the EGR pipe that runs to the exhaust manifolds. The 98 ones did not fit the 2000 exhaust manifolds and cats.
Rob98LS1 is offline   Reply With Quote
Old 10-10-2009, 09:20 PM   #76
willystyle438's Avatar
I recently bought a bone stock 2000 Z28. I am installing a LS6 intake, Off road Pacesetter Headers, ORY (no cats) & SLP cat back. I got the manifolds off. I know about the simulators or about deleting the code by a tuner. My question is about the the hoses from the manifolds to the box in the back driver side left over from install of the headers. What do you do with them? I alreday broke my oil sending unit removing my Intake. I have to deal with that tomorrow.
Need the help... Thanks
willystyle438 is offline   Reply With Quote
Old 10-13-2009, 05:50 PM   #77
sspower23's Avatar
Default Headers banging
Was looking for where it would give Me some info on this matter but read through and nothing so can someone help Me pls?
What exactly is the best way to stop the headers from banging the floorboard? Just installed Pacesetter longtubes, thanks
sspower23 is offline   Reply With Quote
Old 01-07-2010, 12:16 AM   #78
don't own an f-body or anything, but i read somewhere else that you may need to replace your engine mounts, perhaps with stiffer ones?
havent read the article, but i think the answer may be here http://www.ls1tech.com/forums/genera...ion-motor.html
panger is offline   Reply With Quote
Old 01-07-2010, 04:30 PM   #79
okay so your tuner can set it to ready or not faults or whatever to pass smog
Old 02-16-2010, 06:56 PM   #80
MjMaro's Avatar
Please include this in the sticky, very helpful info for removing the air system. Lets people see what is back there before they dig into an ls6 install or AIR removal:
http://www.ls1tech.com/forums/genera...questions.html
MjMaro is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Lighting FAQ VIP1 Appearance & Detailing 11 09-25-2009 09:03 AM
General Maintenance & Repairs FAQ -- PLEASE READ BEFORE STARTING THREAD VIP1 General Maintenance & Repairs 0 05-30-2008 01:27 PM
Stickies are in here! Ragtop 99 Automatic Transmission 1 11-26-2007 07:52 PM
*READ ME FIRST-- Tuning Docs,VE/MAF, SES Lights, FAQS!!!! + more! *01/31/07* horist PCM Diagnostics & Tuning 42 01-24-2007 02:50 PM
Tuning Docs, VE/MAF, SES Lights, FAQS + more! horist Advanced Engineering Tech 32 09-28-2005 11:27 AM
Tags
02, 2000, 2004, air, cadalliac, camaro, corvette, cts, devices, egr, emission, o2, removal, sensors, sim, simulators
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
