Best place to mount the fan control switch
Hey guys I was wondering where some of you guys mounted your slp fan switch
in you car. Also any tricks on getting the wires through the firewall?
I'm gonna mount mine in the ashtray I think once I get around to making the plate. The switch is kind of tall though, so it may have to go somewhere else.
As for the wires, I would run it through the rubber grommet behind the PCM. Remove the pcm and there is a hole right there. Go inside the car and remove the passenger side kick panel and you should see the same hole.
Originally Posted by stillremains
Manual transmission cars also had the option of traction control.
I've never seen a GT/Cobra mustang with traction control and manual. But I've seen alot of auto GTs with traction control.
I figured traction control just didn't come on manuals.......oh well.
I put mine in the hole right above the ashtray looks kinda square and that rubber piece comes out of it thats where mine is.. well i have the m6 so my ashtray is infront of the shifter, and auto would be more towards the console.
Originally Posted by Justin00SS
Mine doesn't. Every auto I've ever seen has it (aside from v6 models) and I've never seen an m6 with it.
Made a plate to take place of the TCS filler unit, to hold the switch, and then some. Here are a few different styles that were put together with plate.
http://i3.photobucket.com/albums/y65...h-panel006.jpg
http://i3.photobucket.com/albums/y65...jection006.jpg
Weird.....I have an M6 and the ashtray is behind the shifter, on the center console.
