Plug Wires
Old 05-12-2006, 08:48 PM
JD_Z28's Avatar
Default Plug Wires
I need some new plug wires, are there any better then the others? What are most of you guys running. Would it be a good idea to up grade since I need them. Im running an STS kit so I figure it may help a bit.
Old 05-12-2006, 08:50 PM
brad8266's Avatar
They are all pretty much the same. I would just get whichever ones come in the color you want and are fairly cheap. Accell, taylors, MSD, are all good wires as are the stock GM wires.
Old 05-12-2006, 08:56 PM
JD_Z28's Avatar
Do you think I would need a thicker wire if im goona be running 700 HP?
Taylor sells a set that is 10.4 mm thick are they really needed.
Old 05-12-2006, 09:19 PM
2K2WS6TA's Avatar
The 10.4 refers to the outer insulation, not the size of the conductor inside the wire, that being said the thicker outer insulation will help the wire to last longer if it comes in contact with something hot enough to melt the insulation.
The stock wires are fine, if you want to change them it's primarily for looks rather than an improvement in performance.
Old 05-12-2006, 10:53 PM
LS69TA's Avatar
MSDs here
Old 05-13-2006, 12:08 AM
That's what she said...
TheBlurLS1's Avatar
LS2 wires here. They have a 90* bend on the end for the plug.
https://ls1tech.com/forums/showpost....5&postcount=11
Old 05-13-2006, 12:12 AM
SSU's Drunk Typing Whore
Lithium's Avatar
Search...lots of good info out there.
MSD's here as well.
Old 05-13-2006, 12:36 AM
indyboom's Avatar
msd 8.5
