problems with qtp y-pipe
Old 05-13-2006, 11:51 AM
Runn's Avatar
Question problems with qtp y-pipe (pics of install)
My y-pipe i got from qtp (along with their headers) hangs real low on the drivers side, How have you fixed this? anyone have pics of how it is suppose to be?
Anyone have pics of the install?
Old 05-13-2006, 02:12 PM
lomaximumta's Avatar
same here. Thats just the way it is. It's touching the floor so you can't get it any higher unless you hack it up. I am just really careful with it.
Old 05-13-2006, 03:27 PM
Runn's Avatar
Mine is not touching the floor... I want it closer to the floor.
Old 05-14-2006, 10:58 AM
Runn's Avatar
Old 05-14-2006, 02:29 PM
dopy's Avatar
my y pipe only bangs the floor under hard acceletion.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 05-15-2006, 10:02 AM
Runn's Avatar
more pics
Old 05-15-2006, 05:11 PM
Roarin_8's Avatar
Old 05-15-2006, 09:31 PM
That's what she said...
TheBlurLS1's Avatar
Thats pretty shitty! The pacesetter y-pipe rides higher than that.
Is it adjustable on the driver side after it makes the dip to pass the body support?
Old 05-15-2006, 10:15 PM
Full-Force's Avatar
Well the Pacesetter Y sits highest of all the 3" y pipes because it has a frame clearance spot on the pipe.
I built my own y pipe using the same Flowmaster merge that the QTP and Mufflex uses. Mine tucks nicely.
Old 05-16-2006, 12:46 AM
Wyckedcamaro's Avatar
those headers look like SEX though
Old 05-16-2006, 07:08 AM
Order 66's Avatar
I have the QTP set up. Mine tucks up higher. Its not easy but it can be adjusted. The pacesetter y pipe is crushed. That is why it tucks up higher. I beleived QTP designed the y pipe to flow. A crushed pipe wont flow that well. I would rather take a better flowing y pipe anyday.
Old 05-16-2006, 09:47 AM
Roarin_8's Avatar
The whole Y pipe is adjustable since it came in seperate parts. The way it's setup now, there's no banging. That exhaust vibrates alot
Old 05-16-2006, 02:27 PM
TheBlurLS1's Avatar
I think I'd give up 3hp so the pictures of my exhaust don't look like those.
If a CATTED y-pipe doesn't rob that much HP, how much do you really think a slightly crushed section is going to rob? What about the people running 2.5" duals from the collectors back?
Old 05-16-2006, 02:50 PM
co.6z28's Avatar
i went with a custom y after the probs my qtp gave me...........its in the trash now
Old 05-16-2006, 03:15 PM
WsSickLs6's Avatar
I had mine perfect, then i installed heads...Now i have minor exhaust leaks and more scraping...I'm going headers with some duals very soon...
Old 05-16-2006, 03:17 PM
Runn's Avatar
Anyone have SFC? i had to remove my SLP SFCs...
Old 05-16-2006, 04:18 PM
Roarin_8's Avatar
I have spohn subframes.
Old 05-17-2006, 08:11 AM
Runn's Avatar
Pics of the install?
Old 05-17-2006, 10:57 AM
Roarin_8's Avatar
If you look at post #7, first picture top right hand corner, you will see a part of the subframe connector. I'll try to take more pics sometime this week if it doesn't rain.
Old 05-18-2006, 09:17 AM
Runn's Avatar
Great
