Front of engine oil leak, what seals should I replace?
Old 05-15-2006, 08:51 AM
nytoy's Avatar
Question Front of engine oil leak, what seals should I replace?
Super long story short, ran a breather at the road course and it wasn't enough, popped the dip-stick and everything. Also pushed a seal out, major front oil leak, but I can't see it when the car is sitting still. I tried cleaning it all with degreaser and watching over and over. It's somewhere in the front of the engine and it hit's the alt and then gets thrown everywhere.
What gaskets can I replace, front cover, oil pan, what else is there crank pulley gasket? I'm assuming for all of these I have to drop the oil pan? I'd like to order all of the possibilites and then just tear into it and replace them all.
Old 05-15-2006, 09:32 AM
conan's Avatar
Timeing cover gasket, oil pan gasket, and crank pully seal (in the timeing cover).
I would start with those and go from there.
Old 05-15-2006, 01:40 PM
nytoy's Avatar
is there a main front cover gasket or are the front cover and timing cover the same thing?
Old 05-15-2006, 01:41 PM
The PAT WS6's Avatar
yeah timing cover gasket and upgraded ur oil pump as well
Old 05-15-2006, 02:21 PM
conan's Avatar
Front main cover, timeing cover... same thing.
