TB cable problem
Old 05-16-2006, 04:30 PM
RollinSScamaro's Avatar
Default TB cable problem
Just got done putting on an LS6 intake and a Shaner S3 throttle body on a 99 SS Camaro.. everything went smooth and then went to bolt the TB up and hook up the linkage for the throttle.. and the linkage is too tight and hold the TB back instead of being closed.. everything is bolted up right and the bracket holding the throttle linkage in place is all exactly the way it was on my 2000 SS.. why would it be any different for a 99?
someone help us figure this one out.. its confusing..
Thanks
Old 05-16-2006, 04:33 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The blade assembly is actually bigger. Swap the shaft and blade out of that housing and use a 99-98 one.
Old 05-16-2006, 06:44 PM
presto_z's Avatar
there is an adjustment on the linkage, undo the plastic clip and you can tighten and loosten it..... if u need pics ill put some up....
Old 05-16-2006, 06:47 PM
presto_z's Avatar
i had the same problem (well mine was to loose, but you can adjust either way) and this was enough for me to figure it out. good luck
Originally Posted by jimmyblue
Snap-clip adjusters on the cruise-TCS and TCS-TB runs.
You may also have slack in the pedal-TCS run which is
not adjjustable, you will either have to bend the pedal
arm or insert a spacer (up to 1" may be needed to get
it to pull full open, at the floorboard).
Old 05-16-2006, 06:51 PM
That's what she said...
TheBlurLS1's Avatar
The 98-98's had a different "cam" for opening the throttle body. Do you still have your old one?
Old 05-16-2006, 06:54 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I knew what I was trying to say. I have the 01' "cam" sitting in the 99 TB in my garage. I used the port matched TB with my intake and swapped the "cam" out.
Old 05-16-2006, 07:40 PM
yea thats what we figured out once we looked at it.. i had no idea that 98-99 were different.. figured with all the research i've done on tech i woulda heard that one before..
But yea how do you adjust that linkage? i was looking at it and couldn't figure it out..
If not i will just swap the "cam" off the 99TB onto the ported/polished 2000 TB.. I'm going to look at my stocker and see if i can figure out how to get it off..
Thanks guys!
Old 05-16-2006, 07:50 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is exactly what I had to do. Take off the blade and then you have 4 screws left after that. Then it slides right out the side.
Old 05-16-2006, 09:55 PM
alright cool... i'll take a look tonight! Thanks for the info
