when do you need bigger injectors?
Old 05-17-2006, 09:15 AM
erikthegoalie's Avatar
Default when do you need bigger injectors?
how do you know when you need to jump to new injectors?
Thanks!
Old 05-17-2006, 09:33 AM
camaroextra's Avatar
425-450 hp, depends on what year you have (98, 01, 02's came with 28lb injectors, 99 and 00 came with 26's)
Get a diagnostics program and check to duty cycle on your injectors, if its close to or over 100% you may need to step up.
with your mods your fine unless you wanna spray a dry shot or something
Old 05-17-2006, 11:00 AM
right thats what i figured,,,
THANKS!
Old 05-17-2006, 01:46 PM
That's what she said...
TheBlurLS1's Avatar
450rwhp and they are usually max'd out. You might also want to throw a new fuel pump in as well.
Old 05-17-2006, 01:55 PM
brad8266's Avatar
RC's calculator tells me that your 28Lb injectors can provide reliable fueling for 460 Flywheel HP(~415 RWHP) at 58 fuel PSI, .45 BSFC, with the injector duty cycle at %80.
Old 05-17-2006, 09:31 PM
TAQuickness's Avatar
When you exceed 80% DC, it's time to upgrade
