Throttle body cable question..
Old 05-17-2006, 01:08 PM
LS1MONSTER's Avatar
Red face Throttle body cable question..
I was cleaning up my engine bay the other day, and noticed how filmsy my throttle body cable was. If I push down on the cable it goes down quite far. My question is, is it supposed to be like that or should it be tight? Hope I made sense here.
Old 05-17-2006, 01:27 PM
MrDude_1's Avatar
theres normally a good bit of slack in it.if you have someone else push it down, you can see your gas pedal go up as they do it..
as long as the cable pulls the throttlebody to WOT, its fine.
Old 05-17-2006, 04:17 PM
presto_z's Avatar
you can adjust it to be tighter.... just do some searching on here...
Old 05-17-2006, 04:45 PM
LS1MONSTER's Avatar
thanks for the replies guys.. now my question is..does it need to be adjusted tighter? Would i notice any difference in throttle response?
Old 05-17-2006, 05:32 PM
presto_z's Avatar
depends on how loose.... if you can almost unhook it from the linkage they i would say yes..... it doesnt have to be super tight, but obviously the less slack the better throttle responce it will have
Old 05-17-2006, 05:52 PM
LS1MONSTER's Avatar
Thanks presto..i'll check it out later today!
Old 05-17-2006, 06:08 PM
LS1MONSTER's Avatar
I'm pretty sure it will need adjustment.. I read the thread where you described adjusting it.. is there a write up with pics or anything on how to do it?
Old 05-17-2006, 06:10 PM
presto_z's Avatar
here is a pic
http://www.mylivingtree.com/7199pic/714/CP793714.jpg
Old 05-17-2006, 06:34 PM
LS1MONSTER's Avatar
Alright I see..so what exactly will I need to do..do I turn them for adjustment? I'm sorry I haven't actually got under the hood of my car yet.. im still at work. Thanks for you help man.
Old 05-17-2006, 06:41 PM
presto_z's Avatar
there are plastic clicps that lift up and u can slide it either way... you will see when you look.... i need a job like that....
Old 05-17-2006, 06:51 PM
LS1MONSTER's Avatar
Awesome..i'll give it a shot. You've been a huge help presto.
