Do you have to change the oil after spraying AmsOil Power Foam into your engine?
I know that with the GM Top End Cleaner they change the oil afterwards because some of the cleaner can creep past the rings. I sprayed some of that AmsOil Power Foam into my throttle body to clean out the intake. It smoked like a son of a bitch out of the exhaust for a good 30 minutes afterwards. I didn't even think to change the oil. Is it necessary with this stuff? Thanks...
Re: Do you have to change the oil after spraying AmsOil Power Foam into your engine?
Don't know for sure, but if it does the same thing as the GM top engine cleaner then yeah I'd go ahead and change it.
Can't hurt right? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
