meziere water pump
That's what she said...
Yes I believe so.
http://www.texas-speed.com/shop/imag...p?file=mez.jpg
Edit - I was wrong, it seems that it uses a SBC style thermostat.
Here's a full writeup.
http://www.ls1howto.com/index.php?article=26
As corrected above, it uses a SBC thermostat. Drill two small holes in the flange, 180 degrees apart & install it in the top of the pump. The holes are to allow air to escape. Stock location for the stat is in the lower water neck. On the Mezier, mount the t stat in the upper neck (return from radiator). This allows air to escape @ the highest point possible.
Also, do not remove the in-line fuse. Meziere won't warantee the pump if the fused protection has been removed.
