wats the diffrence between a 98 and 01 t-body
Old 05-27-2006, 06:52 PM
MiaSSmaro98's Avatar
Default wats the diffrence between a 98 and 01 t-body
hey guys im looking in buying a stock throttle body and i came across a 01 model and the seller sates it needs modification to work on 98 99 models.wats the deal with this?is there alot of modification needed?
Old 05-27-2006, 06:53 PM
That's what she said...
TheBlurLS1's Avatar
You just need to unscrew the blade, remove it, slide out the cam/shaft and slide yours in. The newer ones have a larger cam than the 98-99's.
Use a little blue loctite on the blade screws when you re-install them so they don't get sucked in.
Old 05-27-2006, 07:00 PM
thanks alot man sounds very easy to do
Old 05-28-2006, 07:18 AM
Moderator
davered00ss's Avatar
The cam on the end that the cable attatches to is smaller on the 98/99 cars.
Old 05-28-2006, 03:27 PM
okay so its a no brainor
Old 06-09-2006, 11:47 AM
hey guys one more quick seens i cant find a use 98 t-body and was wondering if i buy a new 01-02 model can i put ti on my car with n problem or will i have to still exchanged parts?
Old 06-09-2006, 01:43 PM
TheBlurLS1's Avatar
You will still need to mod it. They came different from the factory.
Old 06-09-2006, 01:52 PM
wat is the diffrence,and wat will i need to mod
Old 06-09-2006, 02:15 PM
TheBlurLS1's Avatar
You'll need a new TB shaft/cam, they are one piece. The cam is the thing that has the cable passing over it which rotates when you step on the loud pedal.
Old 06-09-2006, 02:53 PM
thats all?
Old 06-09-2006, 03:08 PM
TheBlurLS1's Avatar
Originally Posted by MiaSSmaro98
thats all?
Yep, it's just as simple as swapping them out. Check out the FAQ sticky in this section, it's got TB porting pics and should show how to remove the shaft/cam.
Old 06-09-2006, 03:22 PM
thanks
