Anyone with Jet Hot headers
Just got my Jet Hot's in and the install date for me and my buddy to do them is set for thursday. Its for an 01 WS6. Was wondering if anyone who has them has any suggestions for the install, anything that may make life better that I should know before I start (anything specific to remove to make them slide in ez'er). Also, did anyone have to use O2 extensions for theirs? Thanks for the help!
THEY EASY AS FAR A HEADDER INSTALLS GO i had to knotch my k member because it taped it a bit.. they biggest advice i can give is remove the passnger coilpack before tring to get to the header bolts it makes life much easier also you might wanna have an exhaust shop loosen your cat bolts because their next to impossible to do at home
Originally Posted by RooRnZ28
well i had some trouble fitting the drivers side header in, but the passenger side went in ok... just be calm! headers are great, mine still look new! good luck!
JetHots are not very hard to get in, but take your time with the y-pipe and make sure that you fit it together properly and get it tucked up like it should be. also buy 2 or 3 (can't remember) band-clamps, they don't completely seal the exhaust but are better than the u-bolts.
That's what she said...
https://ls1tech.com/forums/showpost....64&postcount=2
It even says "READ BEFORE POSTING."
That link has everything you'll need to know.
