Exhaust Manifold Bolts??
Old 05-29-2006, 01:23 AM
ramair21's Avatar
Default Exhaust Manifold Bolts??
Where could i get these bolt from? Could i just go to a parts store or go to a hardware store and get them? I really need them cause i plan on doing my LS1 Swap tomorrow Just really need to know where i could get them? Thanks
Old 05-29-2006, 03:23 AM
That's what she said...
TheBlurLS1's Avatar
The stock bolts work awesome, you could pick up a set of OEM's from a stealership if you can find one open.
Dab on a little anti-sieze before you install them, and ONLY use OEM MLS exhaust manifold gaskets.
Old 05-29-2006, 07:08 AM
Jpr5690's Avatar
Lowes Sells Them
Jpr5690's Avatar
Or Reuse Stockers It Really Dosent Matter Their Just Headder Bolts Nothing Fancy There
Old 05-29-2006, 10:12 AM
ramair21's Avatar
do you guys now what size i should get?? OSH usally has these parts. Thanks guys
Old 05-29-2006, 04:22 PM
ShevrolayZ28's Avatar
8mm stud, 1.25 thread pitch, ~1" or ~25mm under head length, or slightly shorter should do the trick. I depends a little on the manifold's flange thickness.
If you get them from Lowe's make sure they are of a good enough grade or they may snap from pressure and heat.
...Honestly, I'd wait and get a set from the stealership (~68 cents per bolt), or order some Breslin or Stage8 locking fasteners online.
Old 05-29-2006, 04:57 PM
ramair21's Avatar
Im going to get the bolts from the "stealership" then. Worth the wait. Do you think i could get the engine mount bolts from there too?? not what hold down the mounts the one that hold the engine and mount together.
Old 05-29-2006, 06:28 PM
Viper's Avatar
If it's on the car originally, you can get it from the General.
