removing 02 sensors easier when exhaust is hot or cold?
I need to remove the rear o2 sensors on my wifes Montero. Those biotches are in there very tight. Would it be any easier if I tried this right when I get home (after a 40 minute commute)? I'm just wondering if the heat/metal expansion would help out.
Originally Posted by ROCNDAV
Tried WD-40. I'm thinking I might just remove the Y pipe (not as big as an F body Y pipe) because they are so hard to get at. THe only thing is that I will then have to buy 3 new gaskets $12 each.
I would borrow a pipe wrench to put on them before I'd remove the Ypipe....just my $.02
Originally Posted by 2K2WS6TA
Try the pb blaster, in my experience it works better then the wd 40
Originally Posted by TheBlurLS1
Whatever the hell you do don't use a cresent wrench. I keep that tool behind glass for emergencies only, as it's far too dangerous for everyday use.....
Originally Posted by Jpr5690
just use a set of tightly applied vice grips and a hammer ive taken off quite a few strpied out things this way and it works better than anything
