Ls6 intake on and now noise?
Had an LS6 intake put on and new clutch. Currently out of injector, new will go in soon, but under acceleration, there is a "shhhhing" sound. what could it be?
Is it more metal sounding or air sounding?? If it's metal sounding, you better have the clutch checked if it sounds more like air then you probably have a vacuum leak somewhere. How is the car running, any driveability issues since the changes???
That's what she said...
Check for vacuum leaks. Did you remove the coolant pipe that runs across the valley cover and replace it?
If you look under the manifold behind the throttle body, and there is a metal tube running under it toward the back of the car, you're going to need to remove the manifold again.
