exhaust leak question
i installed a set of pacesetters about 3-4 months ago, and in the past month i've been hearing what i believe to be a pretty decent exhaust leak. i installed new gm replacement exhaust manifold gaskets when i replaced it, but i never got around to retorqing all the header bolts cuz getting to the driver side is a pita. my question is at this point if i torque them back down do u think it will reseal or should i just pull it apart and replace the gasket? also it seems like gm is the only place i can find gaskets, anybody know anywere else or am in not gonna get much better than gm? also im assuming the added ticking im getting is a combination of an exhaust leak and added valvetrain noise from the much thinner pacesetter, what do u guys think?
And you are right, the added ticking is coming from thinner header walls. You may not even have an exhaust leak at all if all bolts are still torqued properly.
