TB and MAF question
That's what she said...
Originally Posted by JEB Garner
TheBlurLS1, Why should he not port the MAF? I ported mine and de-screened it well over a year ago and have had no problem with it in any way.
Originally Posted by TheBlurLS1
Too many people have ported them and pulled the screens will ill effects. To me, it's not worth the risk for the VERY minimal gains you would experience.
so i should port my STOCK TB then. what are the advantages of that? Who can do it? What do i need??
my other question that you did answer was i was thiniking of taking the MAF screen off.... YES or NO
thanks for your help
Originally Posted by TORCHD 02 TA
ok i thought that that nick williams a person
He owns a shop and CNC's all the NW90 throttle bodies right here in the USA. He also posts on this board under the name "Nick Williams".
Porting the stock throttle body will give you a little more throttle response, and most people usually see 8-10rwhp depending on how well it's hogged out. New Era, Thunder, etc. do ported throttle bodies, or you could do it yourself. There's a writeup for it in JRP's sticky at the top of this page.
Not modify the MAF in any way means don't take the screen out either. You might do it and have no ill effects with very minimal gains, or it could go south and cause the car to run like rolling death. Some people have idle issues, hesitation, and other problems, especially on the A4 cars.
def. dont mod the maf.. like theblur said there are too many potential problems with this... i did however see some of the ill effects of this. after i descreened it and ported it, i had idle issues, and she was throwing codes up left and right. itd be in your best bet to just go ahead and buy a ported maf... if you do however decide to port your own.. just be extremely careful with those little wires when takin the maf apart.
