Need Little Help w/ 160 stat
So last night i installed SLP's cold air flow pac and a 160 stat in my 2001 SS. And i took her out and the water temp wouldnt go any lower then right below the 210 mark. even at a 50 mph criuse she was still hot... Anyone kno why? Because i had a 96 ss and put a 160 in that and ran cool as could be. Thanks
That's what she said...
Originally Posted by WS6nJAX
i had to reset my fans.
Originally Posted by GR33N GoblinM6
because in the 99-02 camaro's.. the coolant gauge is just a dummy gauge. only the 98 Fbod's got the real working temp gauges..
if you want to know what it really is.. get an autometer water temp gauge and check it that way
Both of these guys are correct. If you get the fans re-programmed, it will run cooler, yet stil say 210. Autotap or an aftermarket temp guage will verify.
