160 degree thermo for a 02 z
can you seperate the stat from the housing so i could just go get the stat or do
i have to order the neck and stat as one piece... any way of modding
the old stat to 160 , via cutting spring alittle or drill couple of holes in the stocker
and stead of buying the neck and stat at 50 $$$$$............
Don't thermo wear out eventually anyway? It really isn't a bad idea just to buy a new one, I mean imagine if you accidently cut to much and the thing kept the engine at 140 degrees. That could be bad since the stocker is around 192 degrees.
I mean I know you can seperate the stat from the housing but I haven't seen a place yet that sells just a stat without the housing.
