write-up on the 3-1116 ES poly motor mount?
I bought these and heard its not a direct fit and you had to do some modifications to them.Any pics out there or write-up on what to do?
I've tried a search and couldn't find anything.
Thanks
Mark
Thanks
Mark
Moderator
Re: write-up on the 3-1116 ES poly motor mount?
I just installed the Prothane (PTP-7-512BL) engine mount. This is a direct replacement for the LS1 Fbody engine mount. These are ~$40 (summit) for the pair.
John
John
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slick98ta:
<strong> I bought these and heard its not a direct fit and you had to do some modifications to them.Any pics out there or write-up on what to do?
Thanks
Mark </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sent you mail.
Thanks
Thanks John, I got your mail and checked out that site.I think i can do it <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
John, could you send me that link as well. I'm going to do this pretty soon and would like a guide. Also how do you like the Prothane mounts?
Moderator
The Prothane mounts worked great. No problems with the install or fitment.
I bought them as a pair but I only installed the driver’s side and a friend of mine used the other one on his driver’s side. There are no noticeable additional vibrations. Overall the car feels more solid.
The link is four replies above this one.
Sent you mail.
John
Sent you mail.
John
BTW: Summit, the one's that john is talking about are on back order til the end of march.Atleast that's what the site says.
Restricted User
I installed the older style and have no issues. Just use 3 washers to take up the extra space. You will see where you need the washers when you put the main bolt back in. They go in the rear on the driver side and front on the passenger side.
They might not be on back order now,that was last month when i bought them. Thanks for the replies,I got them both in last weekend with no problems <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I did both sides (one at a time). For the drivers side I did have to pull the alternator but was able to install with my dynatech headers installed. I recall that side was easier than the passenger side as well <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yeah, on the driverside I removed the alternator also.And on the passenger side i moved the A/C out of the way.I did both of mine with the headers off because i was changing them out with different ones.
i just got the prothane mounts, and i got two in the box, but they are not identical.
was i sent a misboxed one? or does the big one go on one side (which one?) and the little one on the other???
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong> i just got the prothane mounts, and i got two in the box, but they are not identical.
was i sent a misboxed one? or does the big one go on one side (which one?) and the little one on the other??? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Both the Prothane (PTP-7-512BL) engine mounts I received were identical. In fact each mount was installed on the driver’s side of two Z28s.
John
John
my p/n was ptp-7-508-BL ?? was i set the wrong ones???
the small one looks just like the stock rubber one , but the big one will most likely fill any gaps in the "clamshell", and i don't know if it will fit or not??
should i be worried?
