Just ported TB
Just ported TB
I just ported my tb and it came out pretty good. I noticed a significant increase in throttle response. Just recommending this freemod to anyone that has some spare time. Took me about 2-3 hrs and 3$ for dremel supplies.
I bondoed the iac and other airway up top, sanded that down smooth and redrilled holes where needed.
Knife edged everything and took out quite a bit of metal everywhere, also took out a few misc bumps and stuff. Cut half the tb shaft off, cut down the screws, etc.
Also did the tb bump stop for true WOT.
Originally Posted by daryl2cb@yahoo.com
glad it worked for you, I have seen tons of horror stories about people who rush in to it and really mess the thing up.
theres tons of people who are AFRAID to do it because they FEAR that they MIGHT screw it up.
but im sure if there are tons of horror stories about people screwing it up, you can link us to a few.
pHEnomIC:
when you say bondoed, you mean epoxied, not actual bondo.... right??
I used bondo. Just to fill in the idle air chamber to smooth it out. I don't think it will be a problem.
Used this guide:
https://ls1tech.com/forums/showthrea...=139142&page=2
Used this guide:
Originally Posted by RrCoX22
your bondo may chip and flake... but good to hear everything worked out
Can some one please explain to me exactly what you do with the two slits that let air pass for idle. Do you just fill them in then redrill them once you are done? Or one of the guides mentioned some thing about puting some ss tubes in there. I want to give it a try but can't quite figure out what I do there.
I just filled them and redrilled with the biggest bit i had (working up from a smaller one to prevent cracks) . It is quite a bit more aerodynamic now.
