Anybody had a noisey fuel pump?
Old 03-06-2003, 10:45 AM
PonchoTA's Avatar
Default Anybody had a noisey fuel pump?
I'm hearing this high-pitched metallic whining coming from the rear of the car. Seems to only make noise after long trips. The car is a '98 TA with 54K miles. Anybody have a similar problem??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 03-06-2003, 01:08 PM
PonchoTA's Avatar
Default Re: Anybody had a noisey fuel pump?
3.23s - why do you ask?
Old 03-06-2003, 01:19 PM
PonchoTA's Avatar
...duh...I see where you are going with this - not the gears. I didn't explain enough....
I'm certain its the fuel pump since it makes noise when the car is stationary and if I just put the key to run.
Old 03-06-2003, 01:40 PM
02SilverWS6's Avatar
OK, if it's the fuel pump, then get a granatelli motor sports fuel pump from Summit. It's a direct replacement! Part# GRN-GM722-2 $125.95ea
your welcome!
Old 03-07-2003, 12:38 AM
Danny2tek's Avatar
what gears do you have?
