Ticking Noise!!!!
Old 03-06-2003, 10:48 AM
John98LS1's Avatar
Default Ticking Noise!!!!
I have a 98Z M6 with Hooker LT's with dual systeam (2 pipes,X-pipe,2 bullit mufflers)I have this Ticking noise that is real loud at the collector but i dont have a leak on the header or exaust (cant spell lol)Iv done the restrictor plate mod on the egr i even replaced the egr valve. Please help !!!! thanks
<small>[ March 06, 2003, 01:09 PM: Message edited by: coolguy ]</small>
Old 03-06-2003, 11:01 AM
MOBE's Avatar
Default Re: Ticking Noise!!!!
Valvetrain clatter/noise. That is what is refered to as "sewing machine" noise. Perfectly normal with LTs.
BTW... I have the same setup, and it does the same thing.
<small>[ March 06, 2003, 11:05 AM: Message edited by: MOBE ]</small>
Old 03-06-2003, 01:06 PM
John98LS1's Avatar
dude its loud!!!! mostly coming from the drivers side too.
Old 03-07-2003, 12:46 AM
John98LS1's Avatar
Old 03-07-2003, 02:38 AM
Jabroni's Avatar
Provided all of your connections are tight, more than likely what you are hearing is the exhaust pulses at the bottom of the primary where it meets collector pipe. It's normal...as long as you're sure there are no leaks.
Old 03-07-2003, 09:23 AM
John98LS1's Avatar
i think it is a leak i just dont know were???
Old 03-08-2003, 02:40 AM
John98LS1's Avatar
Old 03-08-2003, 02:41 AM
John98LS1's Avatar
Old 03-08-2003, 03:58 AM
ngozer's Avatar
i had the same noise and i have mac mid length. all i did was replace my plugs and wires. and it was fine. maybe check you plug wires. my # 8 plug wire was rusted/corroded (spelling).
<small>[ March 08, 2003, 07:14 PM: Message edited by: ngozer ]</small>
Old 03-08-2003, 05:00 AM
redz_02's Avatar
sounds like an exhaust leak.
Old 03-09-2003, 02:09 PM
bae_98Z's Avatar
How 'bout the AIR? I had the same ticking noise, so I got the AIR restrictor plates. Ticking noise gone.
Kyung
Old 03-09-2003, 05:32 PM
HOSS99's Avatar
Maybe a bent push rod. That will make a ticking noise.
Old 03-10-2003, 10:32 AM
Camaro00_SS's Avatar
Your'e not alone.. I got the SLP LT's w/ the Y-pipe, no cats, and the EGR mod too, and I still have that tick! No leaks, head bolts nice and tight. Can't imagine what else to do. Pushrods arrow straight as well. Can't hear it inside the car though (pipe's are too loud! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
Old 03-10-2003, 10:33 AM
Old 03-10-2003, 06:47 PM
WILWAXU's Avatar
Have you done this?
Old 03-10-2003, 07:13 PM
John98LS1's Avatar
yea i did that ****.... damit i cant figure this out!!!!
