McCord powerplate wiring/install???
my mccord didnt come with wiring instructions, so i was wondering if someone here could run me through it cuz i know little about wiring. i will probably run the wires up through the bolt hole under the back seat and under the carpet to the center console, but i need to know exactly how to wire the rest (which wires to tie into, etc.)
http://www.mccordcg.com/mpp/installation.pdf
http://www.mccordcg.com/mpp/installation.htm
both links to installation....the second link is just different formats of the instalation guid... hope this helps
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by WS6FirebirdTA00
do your cutouts leak? mine is rediculous how bad it leaks, I am kind pissed off.
leaks
Before I installed my QTP, I put a small bead of the high temp RTV on the surface where the plate bears against the cut-out mounting plate. It made a nice gasket and it didn't leak. Unfortunately the motor died 4 months later
